Internal Lounge Chat about beefing up your insides here.
3000GT trouble
Old May 26, 2008 | 11:52 AM
Zell311's Avatar
Default 3000GT trouble
hello i recently bought a 95 3000GT with 132000 miles on it
i drove it to the gas station one day last week and the afer i filled the power steering belt broke and made my timing skip a few notches the car car died out and would not start again...
what should i do?
Old May 26, 2008 | 12:02 PM
Zell311's Avatar
Default RE: 3000GT trouble
im almost positive the car is out of time and im not sure how bad the damage to engine is
should i try to fix it
1. myself
2. mechanic
3. drop a new engine?
Old May 26, 2008 | 12:16 PM
Put the timing belt back in time, and try to start it.
Thats pretty much the only way to tell if the motor is okay. You could tear it down if you wanted, but that is a little more costly.
Good luck!
Old May 26, 2008 | 04:48 PM
Zell311's Avatar
thanks anyone else
Old May 26, 2008 | 05:22 PM
Thats pretty much it dude. Nobody else will tell you anything different.
Old May 26, 2008 | 05:24 PM
Zell311's Avatar
95 3000Gt DOHC
At this point I know the I now know the engine is out of time. I has aligned the cam marks to their appropriate position. The crank timing mark is at 6:00 (Straight down). This would be about 130 degrees. Is it a given that the valves have bashed the pistions? RPM was low at the time. Is this engine a 0 clearance engine or and interference situation
Old May 26, 2008 | 05:31 PM
The 6G72 is an interference engine. I am fairly sure that valves smacked into pistons on this one.
Old Jun 8, 2008 | 07:12 AM
sk8dudety's Avatar
yea man looks like ur gonna have to pull off the head and check the valves for damage... if that happened then just rebuild the head, get it port and polished, ect. :-D
beetlenut
Jan 22, 2017 06:11 AM
Audioquest
Aug 16, 2004 06:32 PM
SiriusGrrl
Feb 25, 2004 11:31 AM
eclipsegsx95
Feb 19, 2004 05:04 PM
theguy387
Feb 10, 2004 03:45 AM
