Internal Lounge Chat about beefing up your insides here.
8.0:1 Pistons
Old Feb 20, 2006 | 01:01 PM
99clipsgst's Avatar
Default RE: 8.0:1 Pistons
The kit is not cheap try $600 plus shipping. I have had not problems w/ anything not leaks and holds higher boost better.
Old Feb 20, 2006 | 02:00 PM
Your stock clutch will slip with 300. Sometimes less than that. 300 is the max.
Old Feb 20, 2006 | 11:03 PM
player69x's Avatar
ORIGINAL: Sebba
that is cheap for a engine rebuild kit that gives you all that stuff. just JE PISTONS alone are like 750
Old Feb 22, 2006 | 02:25 PM
99clipsgst's Avatar
Did you even look at the site? It never says JE pistons. here is what my kit came with Top Line basic engine rebuild kit The kit includes: • 8.0:1 4G63 pistons • Rod bearings • Mains • B/S Bearing • Freeze plugs • 4G63 Timing Belt • 4G63 B/S Belt • Full Engine Gasket Set • Front case cover • Oil pump gears Please specify what bearing used in the rebuild kit: Standard, 10 over, 20 over. Also please specify what pistons are used: Standard, 20 over, 40 over.
Slowboy also gave me a cosmetic head gasket for 60 buck too. shipping was fast.
Old Feb 22, 2006 | 08:29 PM
player69x's Avatar
your not getting what im saying. im saying if you just gonna buy some je pistons alone it gonna cost more than that kit. So thats why i said its cheap. look at all the stuff you got for 600 bucks.
Old Feb 24, 2006 | 11:20 PM
slow420a's Avatar
Ya but the stock pistons are good up to 400 hp and I dont think he is looking to rule the world with his car. So in that case for 600 bucks, you get a lowe compression with a stong ring seal, new bearings, hg, oil pump... thats the corn right there, a re ring kit alone is 300 bucks... and that only comes with the rings, head gasket and other misc crap that you need.
RCJr9186
Sep 8, 2005 03:41 PM
RiseoftheEclipse
Feb 15, 2005 08:58 PM
antomx
Sep 24, 2004 06:17 AM
BlackGSTNY
Jul 3, 2004 01:26 AM
