Internal Lounge Chat about beefing up your insides here.
need help
Old Apr 15, 2007 | 02:28 AM
jdm91hf's Avatar
Default need help
i bought a block from a local yard and it came out of a 91 talon tsi turbo now that i look at the block it is not a turbo block can the rods and crank take turbo if i put the turbo pistons in it?
iv searched but cant find this answer thanks for helping the noob
i watched them take it out of the car so i know they did not switch it on me
Old Apr 15, 2007 | 11:20 AM
Default RE: need help
so you got a block from a 91 tsi that is not turbo? that makes no sense. How was it in there in the first place. But if it truely is a non-turbo block then the pistons should be the only thing that need to be changed for lower compression if you plan on running more than 10psi. However according to vfaq the authur ran 19psi and 300hp on the stock nt pistons. however im sure he had an extremely good tune and mods to be able to do this safely. But i still would not reccomend more than 10psi on nt pistons because of the high compression ratio.
Old Apr 15, 2007 | 01:19 PM
I remember you!
The problem is the pistons in the block dont have the T on them. What he is asking is if he puts the turbo pistons he already has into the block... will the rods be able to take it?
What i think is possible.. is that its a built motor... its unlikely .. but possible. Thats why i want a pic
Old Apr 15, 2007 | 04:07 PM
jdm91hf's Avatar
it stock build for this summer then next winter im going all out
with everything lol can the NT pistons handle stock settings?
i know with the higher comp ill have some more power then with turbo pistons.
all im doing to it this summer is a catback and down pipe and no cat
Old Apr 15, 2007 | 04:36 PM
No the NT pistons cannot handle stock turbo settings.
Old Apr 15, 2007 | 04:37 PM
jdm91hf's Avatar
ok damn it thanks lol
ill just put in the turbo pistons oh what is the stock settings?
Old Apr 15, 2007 | 04:39 PM
12psi is the stock boost settings.
Old Apr 15, 2007 | 05:06 PM
jdm91hf's Avatar
thanks for the help
Old Apr 16, 2007 | 12:13 AM
ORIGINAL: Sebba
the stock nt pistons can handle stock boost if it is tuned correctly. Like i said you should be able to run around 10psi on the stock pistons. But you need to have 93 octane and a good tune to prevent detonation
Old Apr 28, 2007 | 08:41 PM
jdm91hf's Avatar
thanks for the help guys!!
91 eclipse gs
1st Generation
Sep 26, 2007 07:03 AM
96eclipsedohc
Feb 8, 2007 09:20 PM
OriginalMirage
Jul 17, 2006 12:53 PM
tuss2oo5
Apr 3, 2006 10:33 PM
Richie03
Dec 12, 2005 11:14 PM
