4wd conversion
Old Feb 27, 2007 | 03:08 PM
big_k's Avatar
Default 4wd conversion
hey just wondering if it is possible to convert my slNA 5spdto 4wd, i don't want to swap out the engine, i will swap tranny if needed but i want to keep a 5spd cause i heard a 6spd on a NA hurts it a lot.i thought i read someplace that ever where else the NA was 4wd except for the US versions so could i import stuff and do the swap and what parts will i need besides rear axle and driveshaft.
Old Feb 27, 2007 | 03:46 PM
thestealth's Avatar
Default RE: 4wd conversion
You have to weld in the attachment points of the rear subframe..the whole subframe.. You'd have to get a transmission/transfer case/transaxle that supports whatever rear end you bolted in...ie. 5 speed or 6 speed. You'd have to disable the AWS. People have done it, and most that have will tell you in the long run it is more economical to just buy an AWD car.
seehow
May 12, 2015 05:08 PM
Dsmoovy
Nov 21, 2011 03:00 PM
greengrounds
Jan 20, 2010 06:59 PM
Vlado26
Apr 8, 2004 09:29 AM
cookie
Apr 1, 2004 01:37 AM
