94 3000gt sl wont start
hey guys i have a problem with my 3000gt about 2 days ago it was running just fine and nowit wont start like if the battery was completly dead soi check the battery i went to buy a new onebecause it already needed oneand it still wont start not even the lights on the dash i already check the battery cables and they are good so i dont really know whats going on please help!!
RE: 94 3000gt sl wont start
you have a fusible link or links that are blown, or a wiring issue. all the main fusible links are in the fuse block under the hood. if those are all good, your going to need to get a wiring schematic and start checking the ignition system. shouldnt be too hard to diagnos.check all the main connectorsto seeif they might have come unplugged or for corrosion.that is a simple system. also, the battery cables can corrode under the plastic coating on them. use a razor blade and go back about4 inches from the cable end and cut into it. if you see alot of white looking dust all over the wiring, you got a corrosion problem. that will not let power get from the battery to the electrical system, causing the exact same problem your describing. good luck, and keep us posted! greg.....
yeah i had that same problem i came home took a shower and went to start it and wouldnt start...took it to a shop my valves r gone,none stress related my seals went out.before i took it to a shop i hooked it up to a computer and it said my fuel pump was out...did some test and my fuel oump was fine...take it to a shop and see
