94 3000gt sl wont start
Old Jan 25, 2009 | 08:32 PM
Chavez89's Avatar
Default 94 3000gt sl wont start
hey guys i have a problem with my 3000gt about 2 days ago it was running just fine and nowit wont start like if the battery was completly dead soi check the battery i went to buy a new onebecause it already needed oneand it still wont start not even the lights on the dash i already check the battery cables and they are good so i dont really know whats going on please help!!
Old Feb 5, 2009 | 11:02 PM
jgbrules's Avatar
Default RE: 94 3000gt sl wont start
you have a fusible link or links that are blown, or a wiring issue. all the main fusible links are in the fuse block under the hood. if those are all good, your going to need to get a wiring schematic and start checking the ignition system. shouldnt be too hard to diagnos.check all the main connectorsto seeif they might have come unplugged or for corrosion.that is a simple system. also, the battery cables can corrode under the plastic coating on them. use a razor blade and go back about4 inches from the cable end and cut into it. if you see alot of white looking dust all over the wiring, you got a corrosion problem. that will not let power get from the battery to the electrical system, causing the exact same problem your describing. good luck, and keep us posted! greg.....
Old Mar 1, 2009 | 06:30 PM
xricer's Avatar
yeah i had that same problem i came home took a shower and went to start it and wouldnt start...took it to a shop my valves r gone,none stress related my seals went out.before i took it to a shop i hooked it up to a computer and it said my fuel pump was out...did some test and my fuel oump was fine...take it to a shop and see
mitzy_3000&eclipse
Jun 11, 2012 05:25 PM
srunnerman
Feb 21, 2010 11:09 AM
jkmd6c
Oct 6, 2009 09:49 PM
GryphonsClaw
Jun 21, 2006 11:33 PM
mach1
Jul 22, 2004 06:52 PM
