always blowing fuses
Old Jan 8, 2008 | 08:46 PM
cd's Avatar
cd
Default always blowing fuses
Hi all ok the problem is I have a 1995 3000gt and going down the road the car just died. With some checking out things i finally replaced a fuse under the hood the eci one and then the car started up and then going down the road to take it home it did it again and now when i put a new fuse in it blows as soon as i turn the key on. I have someone that will look at it but he really needs the wiring schematics for it. If anyone has them or might be able to tell us some things to check. Thanks. And i dont know if this has anything to do with it but now the heater does nothing at all
Old Jan 8, 2008 | 10:04 PM
Default RE: always blowing fuses
Do you have a check engine light?
Old Jan 9, 2008 | 08:18 AM
thestealth's Avatar
You have a short to ground somewhere in the circuit. Have you made any changes to the wiring recently? Added a system, an alarm, did any work around the fusebox?
Old Jan 9, 2008 | 11:36 AM
Im guessing its an o2 sensor. Thats most typical.
Old Jan 9, 2008 | 03:31 PM
cd's Avatar
cd
so in answer to your guestion you think mayby the o2 sensor.Could you explain what effect that would have on the car. I makes since but just so i can tell the person what you mean. As you already know im not very mechanical inclined. Thanks so much for your help. And t the other ? there has been no changes made to the car.
Old Jan 9, 2008 | 09:59 PM
As soon as the wires start to fray on the o2 sensor, and they eventually touch, and short.Then it will just kill the fuse and bam.
Chaspalm
Aug 28, 2014 04:43 AM
Boosted20th
Oct 11, 2010 08:26 PM
sushixxxxx
Nov 17, 2005 04:35 PM
sam i am
Jun 24, 2005 02:00 PM
sam i am
Jun 19, 2005 01:33 PM
