Bleeding Cluth Lines
Old Oct 12, 2006 | 11:11 PM
EveIsle's Avatar
Default Bleeding Cluth Lines
I just replaced my slave cyclinder(( 94 3000gtSL)) about 2 weeks ago and fianlly found the time to bleed my lines, Two days in a row my brother and I sat there for a good 2- 2 1/2 hrs Bleeding the system and my cluth has barely improved to brinmg it self off the floor, So about2-5 hrs total , Wondering how long it takes to Bleed the clutch line manually, I know Not a distant 5hrs and still nothing, also My one friend has a miti-van And I was also wondering The preasure i'd have to set it to to purge the my lines of all air.. Any Helpful hints and tips would be much appreciated, thanks for reading
Old Oct 13, 2006 | 06:32 AM
Default RE: Bleeding Cluth Lines
I think either you have an air leak or your doing something wrong.
Try just leaving the cap off the reservoir and pumping the clutch for about 15 mins... that should make all the bubbles surface. Either that or your master cyl is gone.
coocoobird
1st Generation
Oct 6, 2008 12:45 PM
aorozco2
Jul 24, 2007 04:43 PM
EveIsle
Oct 12, 2006 11:11 PM
zaskar888
Jul 24, 2006 10:09 PM
ictponder
May 17, 2006 01:20 AM
