Car won't start
Old Sep 9, 2008 | 11:58 AM
Eggcellent's Avatar
Default Car won't start
Hello Everyone,
My Car: 1992 Mitsubishi 3000gt SL
Issue: Car will not start without popping clutch. For the longest time I would just unplug the battery cables every time I stopped and turned the car off. Then when I got ready to leave, I would plug the cables and it would start, but sluggish start. Now, I unplug and plug the cables, but the car still won't start until I push it and pop the clutch. I hear a click when I turn the key, but no ignition. Once it is on, it stays on until I turn it off. Then Same thing all over.
Anyone know what causing this to happen? Your help is greatly appreciated.
Last repair (ECU changed)
Old Sep 9, 2008 | 12:15 PM
dsm1990gsx's Avatar
Default RE: Car won't start
Check the battery.
Old Sep 9, 2008 | 01:19 PM
Eggcellent's Avatar
Do you think that the battery cables could be the cause. I changed the terminals, but not the actual cable. I was thinking maybe Alternator or starter since the car stayed on after I pop the clutch and start it. I am going to replace the battery and hope for the best.
Old Sep 9, 2008 | 03:50 PM
Eggcellent's Avatar
Guess it isn't the battery since I just replaced it and still only clicking and no ignition :-( Any ideas?
Old Sep 9, 2008 | 08:43 PM
dsm1990gsx's Avatar
So you turn the key and you get a click...get a prybar and hammer and hit the starter and have someone start the car. Sounds like you have a bad starter.
Old Sep 9, 2008 | 10:06 PM
underpressure2003's Avatar
Sounds like the starter. If you changed the terminals on the safe side get your battery tested at auto zone. But I dout it is the battery. If you just here a click with no ignition starting its the starter.But on the other hand it can be the alternator draining your battery at the same time so check the both of them out. Sounds like alot but does not hurt to check them out. So 2 main things the alternator and the starter. But good luck bro I had the same broblem so check those out.
Old Sep 16, 2008 | 05:37 PM
Eggcellent's Avatar
Thank you all for your help. I changed the starter and it works good now.
mysticrythms
Mar 19, 2014 08:17 PM
eclipsegsx96
Jul 6, 2007 02:45 PM
vivekiny2k
Mar 27, 2007 12:11 AM
Dookitchen
Apr 14, 2006 02:32 AM
Flipz
Dec 12, 2004 04:51 PM
