clutch,flywheel or master cyclinder?
Old Mar 8, 2006 | 12:22 AM
dxwong's Avatar
Default clutch,flywheel or master cyclinder?
i just got a year 94 3000gt. It is a base model. The previous owner modified with clutchmatser stage 1 clutch, fidanza flywheel a year ago. After a week i got it, the clutch wont works. i am wondering the clutch will worn in a year or so? i can change gear without step on the clutch but the car wont move. Any advise thanks
Old Mar 12, 2006 | 01:26 PM
NESpeed's Avatar
Default RE: clutch,flywheel or master cyclinder?
The clutchmaster clutches are junk, it sounds like you have a smoked clutch.....
Old Mar 12, 2006 | 08:34 PM
If he can get it into gear then its more than a clutch... if it was the clutch you wouldnt get it in gear...right?
Old Mar 13, 2006 | 12:24 AM
NESpeed's Avatar
Not necessarily, if the clutch is completely blown apart than you could.
Old Mar 15, 2006 | 02:29 AM
alan92rttt's Avatar
How did it stop working? Was it a sudden stopage (any sounds when it stopped working) or did it just become harder and harder to make the car move.
ANy sounds when you try to drive?
Any smells?
Old Mar 19, 2006 | 01:52 AM
dxwong's Avatar
no..it just slip at first then keep slip till i cant drive it. The engine is all right but the car just wont go..i can smell the clutch burn too...
Old May 17, 2006 | 05:30 AM
Soroosh's Avatar
i had the exact freaking problem with my vr4. it seems to be your transmission shaft. i don't really know what the scientific name is, but some people call it the output shaft of tranny. it might be broke . i could put in gear and when i release it the car would not move. it was like i never put it in gear. output shaft is broken, i say
sk8dudety
Nov 12, 2007 10:37 AM
97spydergs
Oct 29, 2007 02:14 PM
bud660r
Dec 23, 2006 07:30 PM
gsx man
Mar 22, 2005 03:07 AM
Som1Dies2Nite
Dec 1, 2003 08:47 PM
