Clutch/Tranny Problem HELP!!??
Old Feb 6, 2008 | 06:34 PM
Drummerkid505's Avatar
Default Clutch/Tranny Problem HELP!!??
Ok guys, I have a 94 3000 Gt SL, Shes my baby, only 80k miles, and heres the deal.
I was driving my car and i was on the expressway doing about 65-70, Now dumbass *** me was talking on the phone while distractively shifting my gear into 2nd, I let off the clutch and as you could guess it reved high and made a ugly little sound. I threw it neutral as soon as i could. And tried to put the clutch back in, the clutch engaged alright, But I couldnt put it in any gear, I tried fourth, then 5th, And then i heard a grinding sound and it wouldnt engage. I rolled off to the side and let it sit for about 10 minutes, Tried again and I managed to get it in first, and then second very stiffly. I nourished it all the way home but it still grinded a little bit. the clutch feels different now, i havent even dared to drive it, but i started it and the clutch felt a litlle looser pressure, and a little bit shakey, which led me to believe it could be a master cylinder blowout/leak. now i dont know where the hell my clutch master cylinder is located so i can check for a leak. There was no leak on the inside of my firewall.
SO my question is, How do i Assess the problem and find out if i need a new clutch, Master cylinder, Tranny Etc? Im sure this is cake for some of you guys but I myself am not a mechanic lol.
Thank you, and I will appreciatte any help.
Old Feb 23, 2008 | 01:17 AM
VR4 wannabe's Avatar
Default RE: Clutch/Tranny Problem HELP!!??
sounds like you messed up your syncros in the tranny and the springs in your clutch. there are springs in the clutch disc to make for easier clutch engagement and if you shifted down at that speed it would have compressed them pretty heavily.
if you think its your clutch though the master cylinder is really small and just below and to the left of the brake master cylinder (facing forward in the car). its small and white.
Drummerkid505
Feb 6, 2008 06:41 PM
bud660r
Dec 16, 2006 04:34 AM
spyder4g63t
24
Dec 11, 2006 01:09 AM
novetek
Mar 30, 2006 06:34 PM
martpro21
Jan 23, 2006 01:12 AM
