dead fuel injector
Old Nov 24, 2006 | 07:41 PM
kota4u2nv's Avatar
Default dead fuel injector
Just bought a 91 and I have a dead cylinder I found what cylinder it is and I think I found the problem but now I'm stuck. I found that one of my injectors is not gettin any voltage when I checked it so now what? Also is there a way to check the code for the check engine light without a scanner.
THANKS, for any help you may give me
Brandon
Old Nov 24, 2006 | 10:07 PM
Default RE: dead fuel injector
if its not getting any voltage then its not the injector itself.
Old Nov 24, 2006 | 11:51 PM
thestealth's Avatar
Here is the procedure for reading the diagnostic codes with an analog voltmeter.
Old Nov 25, 2006 | 02:00 AM
94 3kgt sl's Avatar
i had the same problem with my 94 sl last week. it turned out to be the sparkplug wires. i changed out the plugs and wires and now it runs better than it did when i got it. try looking at the plus and wires and see how they look.
Old Nov 25, 2006 | 06:22 AM
kota4u2nv's Avatar
I checked the plugs and wires I'm getting spark but just no gas........I just can't think of what else to check I put a new computer thinking that might be the problem but it was not what sends the pulse to the injector or exactly how does the injector work maybe I'm wrong in thinking how the injector works
Old Nov 25, 2006 | 02:36 PM
get a volt meter and check the voltage going to THAT injector. If you get nothing then go backwards... follow the wire untill you get a harness. Locate the positive and negative pins in the harness and test for voltage once again. If you get a reading... then the wire itself is defective and simply replace the wire. If you dont get any reading... then just go back once again.
Old Nov 25, 2006 | 02:54 PM
kota4u2nv's Avatar
that is what I thought I would have to do I was just hopeing that someone might have known the rout so I would not have to trace the wires cuz it runs in some tight places
KF97diamonte
May 5, 2010 01:38 PM
burnmyeyes
Jun 27, 2006 11:16 PM
silveira03
Jun 17, 2006 10:27 AM
dennistan80
Jul 19, 2005 09:42 PM
scone
Jul 3, 2005 10:47 AM
