fog lights
ok so hopefully someone has an answer to this. i have changed out the bulb on my passenger side about 3 times in the past 6 months or so and tonight the damn thing went out again. so this is number four. is there something wrong with the bulbs or is it the fixture...i have no clue. please help. thanks
Are the bulbs breaking or just burnt out? Make sure you do not touch the bulb with your hand or fingers. This will cause the bulb to break when the lights are on. Make sure you are using the correct replacement bulb. Make sure the seal is good.
