fuel
Old Aug 15, 2005 | 03:56 PM
GReddyGST's Avatar
Default fuel
Is there any sufficient way to clean out your fuel system, besides buying fuel injector, and carburator cleaner?
Old Aug 15, 2005 | 05:40 PM
m3kgt_99's Avatar
Default RE: fuel
My suggestion is to go to the nearest track and buy 97 octane fuel. That should clean out any crap that you may have in your lines, rails, or injectors. What are the symptoms you are experiencing right now?
Old Aug 15, 2005 | 08:06 PM
talskinyguy's Avatar
Default RE: fuel
And that will clean it why?
You could buy some injector cleaner, or sea-foam. I have no idea how much they will help, but they will be more effective than putting in a higher octance gas.
Old Aug 15, 2005 | 08:46 PM
DSMTalonAWD51's Avatar
Default RE: fuel
cleaners dont do much at all and if you buy a cheapie brand you may even end up doing more damage. Most likely all you need to do is replace the fuel filter and maybe get the injectors cleaned. If you can afford to have the car out a few days take em out yourself its easy and itl cost you $150
Old Aug 16, 2005 | 09:00 AM
m3kgt_99's Avatar
Default RE: fuel
Well, the filter is easily accessable, and the injectors take like 30 mins to pull out. Unbolt fuel pressure regulator on cam gear side, unbolt rail from other side, take out the 3 top bolts holding the rail in, then pull the rail out. make sure you don't lose your little spacers because they can be a bitch to get back from your engine bay.
Old Aug 17, 2005 | 04:36 PM
GReddyGST's Avatar
Default RE: fuel
Ive already replaced the fuel filter. I was experiencing the lag at 3000 r.p.m.'s and i was driving it the other day on 95 and it woudl barely run at liek 1500 r.p.m's and after like 2 min i had full power past 3000, so it cleaned out whatever was in there. The the next day it lagged againa and a few minutes later i had full power again. So it obviously needs to be cleaned out.
Old Aug 18, 2005 | 12:27 PM
m3kgt_99's Avatar
Default RE: fuel
The only other 2 things that I could say is that your MAF has gone bad or your fuel pressure regulator may be going out. I had a friend with a '99 gsx with the same problem. It simply would NOT rev past 2500 rpm. Although, his car was pretty modified (including a T4 turbo) we found that his MAF was bad so we got an upgraded one. That's pretty much all I got.
Old Aug 18, 2005 | 05:28 PM
GReddyGST's Avatar
Default RE: fuel
The MAF was changed, and i have fuel pressure. The car sat for a year so i think something might have gotten in the fuel system
Germankat
Mar 19, 2008 05:28 PM
Germankat
Mar 19, 2008 06:43 AM
agallardo
Feb 22, 2007 03:46 AM
