gas
Old Nov 28, 2006 | 11:09 PM
mitsuant's Avatar
Default gas
Is it bad to just put regular gas in the car instead of premium?
Old Nov 28, 2006 | 11:15 PM
Default RE: gas
If your owners manual recomends premium then yes it is bad.
Old Nov 28, 2006 | 11:38 PM
thestealth's Avatar
Default RE: gas
Yes, it's only a few more dollars per tankful anyway...
(and yes, the owners manual does specify premium fuel for DOHC's, as does the fuel gauge)
Old Nov 29, 2006 | 04:19 AM
Mr.3000's Avatar
Default RE: gas
You want to put premium because of the fact that you have a 10:1 Compression ratio on the engine. The higher the compression ratio the Higher OCTANE fuel you have to run otherwhise you can get engine knock or predetonation of your air/fuel mixture.
EVOIXGUY
May 14, 2013 05:07 PM
chevegan
Oct 6, 2010 03:52 PM
wmlove3
Aug 9, 2010 10:53 AM
wu2001ok
Jul 2, 2003 01:30 AM
JohnR
Jun 4, 2003 08:31 PM
