How can I check for fuel issues?
I finally took my 1992 3000GT out for the first time since January, a lot of devastation that month. She started up fine, went around the block fine, oil pressure and temp and voltage were normal. I tried going futher. About a mile from my house the oil light comes on, and I check the gauge and its sitting low. By now the car is not really responding when I hit the gas so I kinda rolled off to a side street. Pushed it home.
Now I was told that the oil gauge is known to be horribly wrong in these cars so Im hoping that its just a cooincidence. Not ruling it out but thinking of other possible issues. Im wondering if there wasnt enough fuel detonating if that could be the reason it was bogging down, not reacting to the gas pedal. I did notice that if you sat there in neutral and pumped the gas several times that it would slowly rise up as high as you wanted but when driving it didnt go beyond 2500 rpm. Now Im not ruling out the oil thing, Ill be checking oil pressure with a test kit, not trusting the known-to-be-demented gauge. But at the same time how could I check for fuel pressure? For all I know I could just need a new fuel filter and I was worried about an oil pump.
5star
Oct 31, 2007 07:44 AM
