I NEED YOUR HELP!! CAN I?...
Old Apr 30, 2007 | 08:51 PM
danwestm's Avatar
Default I NEED YOUR HELP!! CAN I?...
I own a 1998 3000GT SL 24 Valve DOHC V6. Im thinking of doing an engine swap to take advantage of some quick, cheap much needed horsepower. I threw on some new rims and suspension and some killer subs and because of that the car is even heavier than it was.
It seems to me that my engine is the twin of the 6g72 TT that came in the VR4. Now I understand that there may be some minor issues I may have to tweak to get that engine to work but other than that I'd like to know if it will work with the current auto trans. I dont really have the cash to go all wheel drive and adda 6 speed manual trans right now. The reason I want this engine is because it supposedly uses the same mounts and ecu and will also be easy to add a driveshaft and rear axel to make this thing AWD later. Can it be done and what problems will I run into?
[IMG]local://upfiles/12399/C66EE6E8E60C472DB74A8CB494A98FD7.jpg[/IMG]
Old Apr 30, 2007 | 08:59 PM
Default RE: I NEED YOUR HELP!! CAN I?...
Moved to 3000gt section, and try a search on here. There is a couple threads on this
Old May 1, 2007 | 02:50 AM
5Tizzle's Avatar
Im gonna answer this just because nobody else is stepping up to it. Its not worth the work! END
Old May 1, 2007 | 11:30 AM
thestealth's Avatar
Yes, the 6g72TT engine will fit with minimal hassle. 3 of the 4 engine mounts are the same, the front engine mount is a little different. The ECU's are not the same. The TT ECU will not communicate with the the TCU, but people have done the swap with an auto tranny. As far as I know, they have to shift through the gears manually. No, it will not be easy to add the rear subframe from a VR4.
Old May 1, 2007 | 11:37 AM
Dusty Eclipse's Avatar
Wait, not all 3kGTs have 6g72? What is that car in that top post??
Old May 1, 2007 | 12:14 PM
thestealth's Avatar
Yes, all 3k's have a 6g72 based engine. I meant to add a "TT".
Old May 1, 2007 | 05:37 PM
doulos's Avatar
If you want the HP, just buy a Super Charger for the N/A, or Lower the Compression and TT it. FWD is fine if you get a LSD. Or you could go buck wild and Big Single it. You would have to get new Pistons and rebuild the heads to get the Compression down, but with a Big single a FWD 3k turns into a freeway Monster.
Greg
Driver99
Feb 25, 2008 02:16 AM
danwestm
Apr 30, 2007 08:51 PM
Patrick
Aug 23, 2006 06:20 PM
Patrick
Jun 1, 2006 09:05 PM
puffy
Jun 7, 2004 05:16 PM
