low oil pressure
Old May 24, 2007 | 07:04 PM
aowen2's Avatar
Default low oil pressure
I have a 95 3kgt base model, and I noticed while driving that the oil pressure needle hangs about one quarter or less up the guage while idling. When driving it gets up to just above the larger mark. Is this normal, or should the needle be between the two large ticks at all times. Thanks.
Old May 24, 2007 | 08:31 PM
turbosprentice's Avatar
Default RE: low oil pressure
my guess is that it's fine, i have a '96 base model. mine is doing the same exact thing. i took it to a local shop and they said that it isn't a problem and that it's pretty much normal for the 3kgt since he has a '95 model too and it's doing the same exact thing.
Old May 24, 2007 | 08:44 PM
silvercoupe97's Avatar
Sounds like the oil pressure sender needs to be changed.
Old May 24, 2007 | 10:15 PM
aowen2's Avatar
SilverCoupe, is your car different. And why do you say the sender needs to be changed?
Old May 25, 2007 | 08:20 AM
thestealth's Avatar
I wouldn't change the sender out just yet. Does it ever drop to zero? Does the oil light ever come on? Does it have erratic behaviour?
At idle, the oil gauge in many of these cars do read low, but like most cars, the factory oil guages are not much better than idiot lights, to slow to inform you of impending doom.
I wouldn't worry about it too much, if this has been the norm since you've owned the car.
Old May 28, 2007 | 08:50 AM
kornkid1215's Avatar
i have a 93 vr4 witha 92 vr4 engine and mine does that do and the light will flicker but oil fine idk what the deal is
Old May 29, 2007 | 09:19 PM
Manybrews's Avatar
thats exactly how ALL oil pumps on all engines operate.
oil pressure is in direct relation to engine speed. It also says that in your owners manual (you know, the thing thats probably still wrapped in celophane in your glove box).
turbo1600
Apr 25, 2021 01:58 PM
colomonty
Jul 1, 2010 08:05 AM
ronnie Galant 02
Aug 8, 2008 04:20 PM
zeanimal2001
1st Generation
May 29, 2007 01:22 AM
FlipNNVH
Oct 11, 2006 12:52 AM
