94 3000GT SL NON-TURBO OIL
Old May 30, 2007 | 12:18 AM
theend's Avatar
Default 94 3000GT SL NON-TURBO OIL
Hi, like I said before I bought a 94 SL for 6,000 and i came without an owners manual. Does anyone know where to get one? I checked on 3sx.com they dont have it and on ebay i did not see. What oil does a 94 SL take? My mechanic told me to use 20w50 bc its starting to burn a little oil and/or leak, because 20w50 it is thicker.. While I replaced engine seals and will replace the oil cap beause i see its leaking from there. Mitsubishi told me use 10w30 or 10w40 for higher mileage. mine just has over 100,000 (castrol gtx good? mobil1?). And should I use synthetic? And what about the performance K&N oil filter: any good? Thanks guys.
Old May 30, 2007 | 10:57 AM
thestealth's Avatar
Default RE: 94 3000GT SL NON-TURBO OIL
I use 10-40 in my NA Stealth. Castrol will work fine. No need to swap to synthetic. I haven't heard of any problems with the K&N filter. Don't use Fram, there have been a few reports of seized oil pumps because of crappy check valves in the filter falling apart.
Old May 30, 2007 | 11:08 AM
Synthetic is much better. Do you know if the car has synthetic in it right now?
Old May 30, 2007 | 11:28 AM
thestealth's Avatar
Synthetic is better...but for a car with over 100K miles and non-turbo, there is really no need for the added expense...that is assuming it's always had dino oil in it.
joshr12
Sep 13, 2012 03:09 PM
theend
Jan 21, 2010 09:00 PM
theend
Sep 9, 2007 11:07 PM
theend
Aug 27, 2007 03:45 PM
bmvardar33
Aug 16, 2007 05:14 AM
