1991 3000gt sl non turbo
Old Jun 3, 2012 | 01:16 PM
joshr12's Avatar
Default 1991 3000gt sl non turbo
my car is cutting (bogging) at 4500rpm when i put my foot into it.
it drives fine other than that. i can take it up to the limiter if i dont floor it.
there are no lights on.
and it idles at 800
i replaces the plugs wires and fuel filter, HELP
Old Sep 8, 2012 | 04:33 AM
Yez's Avatar
Yez
I had the same problem after putting a refurbished ECU Module in. Eventually the ECU failed and car won't run at all now. Buying a good used mod on ebay to see if that
helps. I did the same things you did with plugs, wires and even a new fuel pump to
no avail. Mike
Old Sep 13, 2012 | 03:09 PM
Yez's Avatar
Yez
Narrowed it down to a vacuum lead or bad wiring ground,.
FastC6Vette
Oct 10, 2008 09:23 PM
bmvardar33
Aug 16, 2007 05:14 AM
theend
May 30, 2007 11:28 AM
barex
Sep 25, 2006 01:16 AM
rbland
Oct 7, 2004 04:16 AM
