totally lost......NEED HELP PLEASE.....
Old Sep 26, 2012 | 07:01 PM
mitsnewbie68's Avatar
Default totally lost......NEED HELP PLEASE.....
got a 93 3000gt....had new heads,timing belt,fuel pump,water pump put on,new computer....has no power to fuel pump.swapped out mfi relay with another one and still nothing.checked fuses and all seem ok.pump runs if hooked directly to battery.could there be an issue with anti theft???any other ideas or help is appreciated.thanks
Old Sep 26, 2012 | 07:54 PM
also note that the car wont start when i hook fuel pump up directly to battery either.it just turns over but it does have compression and spark.
Old Sep 27, 2012 | 11:42 PM
mxmikie's Avatar
any burnt caps in the ecm ????
Old Sep 29, 2012 | 03:14 PM
its brand new.....
Old Sep 30, 2012 | 12:55 AM
mxmikie's Avatar
Originally Posted by mitsnewbie68
its brand new.....
what does that mean ????
Old Sep 30, 2012 | 12:06 PM
that means the ecm is brand new like i said originaly....dont know what else to check for so thats why i asked on here.
Old Oct 1, 2012 | 08:57 PM
mxmikie's Avatar
cause it is new dont mean that it is good check it for burnt caps
Old Oct 3, 2012 | 09:52 AM
toddrs93's Avatar
did it run before all this?
You need to see if fuel is actually spraying. when your cranking it with the fuel pump getting power, pull the plugs and see if they are wet from fuel. Make sure timing is set correctly. fuel pump gets signal from the mfi which gets signal from the ecu and thats it. if its a tt there is also a fuel pump relay and resistor up under the engine bay fuse box that could be bad.
mda185
Jul 14, 2013 06:42 PM
kenuck
Apr 1, 2013 04:09 PM
joeuspe
Aug 12, 2011 07:42 PM
angel73
Jun 21, 2011 12:17 PM
jshem746
32
Nov 6, 2007 05:21 AM
