Idle problem 1991 Laser 2.0L non turbo
Old Jul 4, 2004 | 02:14 PM
rbland's Avatar
Default Idle problem 1991 Laser 2.0L non turbo
I am having a problem in that my idle surges from 200 rpm to about 2000 rpm when first started. It seems to correct itself once operating temperature is reached. As stated in subject line it is a 91 Laser 2.0L non turbo 5 speed. I have replaced the TPS as it was dead, but there is little improvement. Any suggestions group??
Old Jul 5, 2004 | 02:46 PM
Seth's Avatar
Default RE: Idle problem 1991 Laser 2.0L non turbo
Isn't it normal for it to do that if its an EFI system as when you start the engine when its cold it would reach around 2000 rpm acting like a choke so the engine won't stall requiring a ritch mixture of fuel untill the engine warms.
Old Jul 9, 2004 | 01:46 AM
rbland's Avatar
Hi. Thanks for the response. It would be normal if the revs stayed high (like a choke) but as I stated the idle surges up and down continuously until the engine reaches operating temperature. I am wondering if the idle speed control servo controls this. Any suggestions?
Old Sep 23, 2004 | 09:35 PM
answers's Avatar
I have a 93 Eclipse and it would idle up and down ,probably 300 to 4oo rpms while idleing ,and they replaced the idle air control valve to fix it but other than that the car ran fine but if you would give it gas the throtle would stay high and slowly go back down to the eratic idle . you would never know somthing was wrong driving down the highway.
Old Oct 7, 2004 | 04:16 AM
EclipseGSRoadRacer's Avatar
I had this problem on my eclipse. There's a sensor right below the intake piping on the intake manifold, I believe it's right before the throttle body. It's attached by two small bolts. Take it off. The sensor can be taken apart to be cleaned and most off the time it's not too late for the sensor. There are three screws you need to take out to take apart the sensor. Clean the inside of the sensor with carb cleaner. That's right, carb cleaner, not throttle body cleaner. For some reason it works better to clean the sensor than throttlebody cleaner. I even shot some silicone inside to keep the parts sliding nice inside. Put everything together, plug the sensor in and you should be ok. I was told if you let the car's idle surge like that, you risk blowing out the ECU.
joshr12
Sep 13, 2012 03:09 PM
jayboy74
Apr 6, 2010 01:30 PM
tumadre
Nov 20, 2006 03:10 AM
barex
Sep 25, 2006 01:16 AM
turbotuned
Nov 29, 2005 03:33 AM
