My 3000GT doesn't always want to start...
Old Dec 26, 2007 | 05:44 PM
mitsugirlie's Avatar
Default My 3000GT doesn't always want to start...
Sometimes when I turn the key it just clicks, all of the accessories turn on but the engine doesn't even try to turn over. Then, after a few turns of the key it starts and sounds fine (strong even). I have replaced the battery and the starter. Actually, I've replaced the starter three times now. Last week when the current starter was put in the mechanic said all of my connections looked good and the only thing it could be was that my starter was a dud. It did start 100% of the time for the first few days and then the same old problem again. Any ideas?
Just for the record, it has a new clutch andidle speed control motor, and will start with a jump.
Old Dec 26, 2007 | 05:56 PM
kweef's Avatar
Default RE: My 3000GT doesn't always want to start...
well that sucks...idk much bout the startin systems in the 3000 GT, did u ever have the ingnition switch or the starter relay checked out?
Old Dec 26, 2007 | 09:21 PM
Spark plugs and spark plug wires. Use NGK for the spark plugs and factory Mitsubishi wires.
Old Dec 27, 2007 | 07:28 AM
thestealth's Avatar
Do you hear a click coming from the passenger side footwell when it doesn't start? Do you hear the starter solenoic click when you try to start it? What year car do you have?
Old Dec 27, 2007 | 02:41 PM
I will have the plugs and wires checked/replaced, it would be great if that's all it needs.
It is a 97. I hadn't noticed, but thinking about it, it does sound like the clicking is on the passenger side. I don't knowif it is asolenoic click, whatwould that sound like?
Old Dec 27, 2007 | 02:46 PM
kweef's Avatar
it should just sound like a click lol
Old Dec 28, 2007 | 02:33 PM
thestealth's Avatar
You could either have a bad starter solenoid, but since your starter was replaced a couple a few times, I don't think that is the case. The starter relay could be going bad, but usually when they go bad, they go bad. The ECU could be on it's way out. You could also have the "click click start" problem many 3s's have. Read this thread to see if the syptoms sound similar to your problem
http://www.3si.org/forum/showthread....ht=click+start
Old Jan 2, 2008 | 06:01 PM
The "click click start" thread hit the nail on the head! I'll be attempting the relay fix this week. I feel so much more optimisticnow, thanks so much for the suggestions!
civicdestroyer
Aug 11, 2009 09:07 AM
R@lli@rtR@cer
Sep 14, 2007 12:54 PM
1995MONTYSR
Sep 1, 2007 10:54 PM
Marah
15
Feb 28, 2007 07:58 AM
deltadave
Dec 6, 2006 08:09 PM
