N/A to Twin Turbo Conversion HELP!!
Old Apr 18, 2008 | 03:14 AM
Ralliart3000's Avatar
Default N/A to Twin Turbo Conversion HELP!!
alright i own two cars as of now i have a 1995 mitsubishi 3000gt SL that i have dumped alot of money into the paintjob (if anyone wants me to email pics just let me know), audio, etc....
my best friend owned a 1995 dodge stealth awd tt and i am planning on basically switching every componet on the stealth to my 3000gt what i want to know isif anyone has tried this before and how it turned out and also how much would it cost me .. theres just oneproblem with the stealth he told me that he bent thevalves or something likebut thats the least of my worries ..
Old Apr 30, 2008 | 05:14 PM
redline3kgt's Avatar
Default RE: N/A to Twin Turbo Conversion HELP!!
you can swap the ECU, Injectors, Fuel Pump, Oil Pan, Oil Lines, Oil Cooler, Turbos, Manifolds,Exhaust,Intercoolers, etc, etc and install it on your motor. Everything is Bolt on and plug and play. I would encourage you to buy a datalogger,an electronic or manual boost controller to control boost (set it at 8psi and datalog),a boost gauge,and possibly a new clutch. The conversion is rather simple, and if you have the skills required, it should be completed within a weekend.
The AWD, however, is extremely difficult to install on your vehicle, because the subframe wont bolt on, you'll need to weld it on.
You dont need to worry about the valves if you're keeping your stock heads.
Old May 1, 2008 | 01:47 PM
EMC 3000GT's Avatar
Doing the AWD conversion is a waste of time money and resourses. The NA and TT chasis (like stated above) Is different
If you want to the TT conversion you have two options
1: Drop the TT motor in your car (not gonna work if the valves are bent)
2: Turbo your NA motor (easyish as everything will bolt up if you buy the right parts.
Check out Bobthegreats guide.
http://www.bobthegreat.com/pages/myc...rbo/index.html
If you have any questions let me know.
Matt Grace
Jun 26, 2014 10:49 PM
Janarris
Dec 14, 2007 04:47 PM
3sMike3s(PA)
Apr 24, 2004 05:38 PM
paulcook
Jan 6, 2004 02:47 AM
thedozzman
Sep 18, 2003 06:49 PM
