Need some advice!!!
Im helping out a buddy of mine redo his 1991 vr4 and it ran completely fine, then he let it sit for about 2 months and i just recently went to pick it up, and now it doesnt want to rev passed 5 grand, ive checked the spark plugs and the air box and everything seems to be fine, im not sure wut their supposed to boost at but it only hits 6 psi, any help or ideas would be appreciated, thanks in advance
6psi is way to low for a vr4, so there is probably an issue with that. Maybe i would try checking out the turbo to make sure it is getting the proper oil and spooling correctly. But before even getting into that, you want to check your distributer like jdmvr4300 said. Start with the basics and you might end up saving yourself a lot of time. Can you describe how it sounds when it hits 5k? Is it missing or what? How does it drive?
well rite when it gets to about 5 grand it just stops climbing, it almost seems like its loaded up, it doesnt miss or anything like that just doesnt want to rev, does anyone think the injectors might be clogged since its been sitting soo long ???
ORIGINAL: JDMVR43000
Check distributor
Check distributor
So when you sitting still, not in gear. And you floor it will it climb all the way to 7, or does it get to 5 and stop? Where are you seeing the 6psi? the stock gauge? It sounds like your engine is not getting enough air. Is it smoking at all? If so what color is the smoke?
1998blackgst 240
04-12-2005 12:56 PM
rajawal1
04-08-2005 06:10 PM
