Need some advice!!!
Old Jul 25, 2005 | 05:28 AM
evoracer32's Avatar
Default Need some advice!!!
Im helping out a buddy of mine redo his 1991 vr4 and it ran completely fine, then he let it sit for about 2 months and i just recently went to pick it up, and now it doesnt want to rev passed 5 grand, ive checked the spark plugs and the air box and everything seems to be fine, im not sure wut their supposed to boost at but it only hits 6 psi, any help or ideas would be appreciated, thanks in advance
Old Jul 27, 2005 | 04:18 AM
JDMVR43000's Avatar
Default RE: Need some advice!!!
Check distributor
Old Jul 27, 2005 | 02:28 PM
Gregory's Avatar
6psi is way to low for a vr4, so there is probably an issue with that. Maybe i would try checking out the turbo to make sure it is getting the proper oil and spooling correctly. But before even getting into that, you want to check your distributer like jdmvr4300 said. Start with the basics and you might end up saving yourself a lot of time. Can you describe how it sounds when it hits 5k? Is it missing or what? How does it drive?
Old Jul 27, 2005 | 09:42 PM
evoracer32's Avatar
well rite when it gets to about 5 grand it just stops climbing, it almost seems like its loaded up, it doesnt miss or anything like that just doesnt want to rev, does anyone think the injectors might be clogged since its been sitting soo long ???
Old Jul 29, 2005 | 12:18 AM
wicked_outlander's Avatar
check your fuel.....fuel expires too.
Old Aug 6, 2005 | 05:59 PM
talskinyguy's Avatar
ORIGINAL: JDMVR43000
Check distributor
Maybe he should check his blinker fluid too.......
So when you sitting still, not in gear. And you floor it will it climb all the way to 7, or does it get to 5 and stop? Where are you seeing the 6psi? the stock gauge? It sounds like your engine is not getting enough air. Is it smoking at all? If so what color is the smoke?
Old Aug 7, 2005 | 04:23 PM
StealthTT's Avatar
When was the last time the fuel filter was changed I had that problem too!
SxyNTwisted86
Nov 1, 2006 02:04 AM
bluballz07
Oct 18, 2006 11:33 PM
DixonsGst
Oct 8, 2006 05:21 PM
1998blackgst 240
Apr 12, 2005 12:56 PM
rajawal1
Apr 8, 2005 06:10 PM
