stock twine turbo boost
Old Mar 31, 2007 | 05:09 PM
turbosprentice's Avatar
Default stock twine turbo boost
i was wondering whats the stock boost for the 3000gt vr4. i have a na gt and i want to do a turbo up grade. but before i do anything i want to know the stock boost of the vr4 turbos. i want to turbo up grade my gt with the stock motor with minimal engine replacement parts. i may up grade cam shafts, but i will be needing bigger injectors(maybe stock vr4), fuel pump(walbro if they have them), an ecu reflash, and some other minor up grades. i want to use the stock vr4 twine turbo as base for my up grade. let me now what else i'm missing and how much i'll be spending on it. need help. thanks.
Old Mar 31, 2007 | 05:11 PM
Default RE: stock twine turbo boost
Why did you post this twice?
Old Mar 31, 2007 | 05:12 PM
mass up on one of them. sorry. still need help.
Old Apr 7, 2007 | 06:54 PM
doulos's Avatar
if your going to do a TT Converion on a 10:1 block, check out the NA to forced induction section on the forums @ 3si.org. I believe the Stock 9b's from the factory push 6-8lbs.
Old May 13, 2007 | 12:29 AM
MitsiGTO's Avatar
well on my stock twn turbo GTO in any gear as soon as u put your foot down it go's up to 10psi then drops very fast down to 6psi and stays there 4 the rest of the revs i think it holds 10psi till it gets to about 4,500rpm it drops very fast to 6 psi and stays there i have asked y it dose this and i have been told the back of the turbos are to small to hold the boost up hope this helps
se4448
Nov 6, 2007 01:25 PM
anko_kun
Dec 24, 2006 07:48 PM
thehintons06
Dec 20, 2006 10:20 PM
sonoftheking
Mar 5, 2005 06:56 AM
GReddyGST
Sep 17, 2004 04:58 PM
