Stock Boost
Old Sep 13, 2004 | 08:32 PM
GReddyGST's Avatar
Default Stock Boost
Recently i got a G-Reddy Profec II Spec B electronic boost controller...In order for it to work properly i need to know wat the turbos runs stock for boost...( '97 spyder gst ) and hopefully wat theyre capable of keeping up with.
Old Sep 14, 2004 | 02:05 AM
HotNix95gsx's Avatar
Default RE: Stock Boost
i think it might be 15psi on a stock turbo but i dont know for sure...... but with 15 psi youre capable of keeping up with quite a few cars.....and im not talkin civics and geo metros
Old Sep 15, 2004 | 11:48 PM
nate5023's Avatar
Max PSI is 15, and usually 2nd gens run 13 or 14 psi so hopefully yours is low, so you will get a big gain. But I run my turbo at 15 1/2 PSI and it hasn't blown.
Old Sep 17, 2004 | 11:35 AM
SpyderGS's Avatar
Yeah, i believe the 2g's run 13psi stock, maybe 14psi on the 95-96. However, be aware that just cranking up the boost to like 18-19psi may not do you a lot of good. Once the T-to small-25 reach's about 17psi, it's at its max efficiency and heats the air much more rapidly...eventually causing a loss in power. Running about 17psi with stock everything else may net you a high 13 seconds and about 250-260hp(crank). Next upgrade should either be a turbo upgrade(16g or even T28) or SMIC upgrade(MkIV Supra SMIC works great for not a lot of cash and sleeper look).
Old Sep 17, 2004 | 04:58 PM
1398spdr's Avatar
also keep in mind if your running more boost you need better exahust air flow, the stock exahust can handle a lot of boost, but is very restrictive, i would also port and polish the TB, get a new fuel rail and injectors and fuel pump, cause the more boost you run the more fuel you use, minor things like that will help greatly in the efficiency of the turbo and how much boost you can run...... another idea - keeping the heat levels down is important like spyder said, powder coating, from what i hear, is a great way to keep heat levels down and again helps create more hp........
se4448
Nov 6, 2007 01:25 PM
turbosprentice
May 13, 2007 12:29 AM
anko_kun
Dec 24, 2006 07:48 PM
thehintons06
Dec 20, 2006 10:20 PM
sonoftheking
Mar 5, 2005 06:56 AM
