is there a suppose to be a whole in tranny?
Old Aug 17, 2007 | 12:11 PM
nastynate's Avatar
Default is there a suppose to be a whole in tranny?
this has to deal with my previous post about fluid leaking on/out of the transmission. i jacked up the car, after letting it sit all night, and i could see where the puddle of fluid was coming from. there is a little squarehole at the bottom of the transmission. Its almost against the gasket, but not touching it. umm thereare some identification numbers/letters like 2-3 inches from the hole. Its almost a perfect little square hole.
Is that hole suppose to be there? if so is it the gasket that connects tranny to engine?
Old Aug 17, 2007 | 12:27 PM
thestealth's Avatar
Default RE: is there a suppose to be a whole in tranny?
Can you get a picture of the hole? Is it right next to the engine block? I'm just guessing, but it could be a built in "weep" hole, in case one of your tranny seals goes bad, or a main seal. It would allow the oil to drain out so your clutch doesn't get soaked with oil. That's just a guess though without being able to actually see the hole.
Old Aug 17, 2007 | 12:35 PM
nastynate's Avatar
here are pictures of that hole
Old Aug 17, 2007 | 12:46 PM
thestealth's Avatar
I can't really tell from those (small) pictures. Is the hole not square? It looks like one side of it tapers off to where the bell housing/block meet.
Old Aug 17, 2007 | 01:54 PM
nastynate's Avatar
yea, the whole is not perfectly square after re-examining it. umm its right where the bellhousing and block meet. but why should there be fluid?
Old Aug 17, 2007 | 02:33 PM
thestealth's Avatar
There shouldn't be fluid in that area. That is where the clutch/pressure plate is. I can only assume your rear main is leaking oil, or a shaft seal for your tranny is leaking. Are you losing gear oil? If so, a shaft seal is likely the culprit.
Old Aug 17, 2007 | 03:04 PM
nastynate's Avatar
this is probably a stupid question; how do i tell if i am losing gear oil?
barelyboostin
Jul 2, 2008 08:45 PM
BrunoBoy650
Mar 7, 2008 01:24 AM
06OutlanderSE
Jul 27, 2006 04:03 PM
panama_af
Dec 14, 2005 10:13 PM
DNeinstadt
Aug 4, 2005 02:19 PM
