Top performance
Old Nov 6, 2006 | 02:28 AM
Braunstein82's Avatar
Default Top performance
Just bought a 94 sl, havent even messed with a import motor only fords. Want to know where is a good lower cost start to power it up. What are a few things i should do and how much do they cost and where to get them. Thanks
Matthew
Old Nov 6, 2006 | 02:31 AM
davidmitsusrock's Avatar
Default RE: Top performance
i would check out www.dynamicracing.com ull find quite a few parts on there.
Old Nov 6, 2006 | 03:06 PM
VR4GARY's Avatar
I would start with a test pipe to replace the cat, and a high-volume air filter. both will run you anywhere from $60 to $160. Added HP will be about 15 to 25. You will feel the difference.
Old Nov 28, 2006 | 08:48 AM
Mr.3000's Avatar
The truth is that your 94 SL weighs in at just shy of 3500lbs. It is heavy. If your really want power you need to go forced induction. You could spend upwards of 2Grand on parts and upgrades and barely be putting down 200fwhp on the dyno. I would suggest to you that before you start buying bolt ons for your NA...ask yourself these questions:
1. How much power do I want?
2. How fast to 60/quarter mile do I want to go?
3. How much money do I have to spend?
If your answer to 1 is over 300 then you need to either do a tt conversion or a full tt swap(the latter of which is more expensive but better in the long run and easier)
If your answer to 2 is less than 5 seconds to 60 and 13's or less in the quarter, once again go TT
If your answer to 3 is atleast 3 Grand TT is the best way to go to maximize your cash. I spent over $1200 In performance mods for my 3/s and if I was to believe the numbers they(as in the vendors) said I would gain then I would have about 275hp right now at the engine. If I was to dyno at the road I would prob be doing about 197 and at the engine about 240. Just not worth it. GO TT!!
tigermission1
Jan 9, 2009 08:34 PM
metalmilitia
May 10, 2008 02:17 PM
umartin
Feb 3, 2006 05:40 PM
taylor61387
Jul 9, 2004 11:58 AM
nimitz309
Nov 11, 2003 07:25 AM
