vr4 transfer case Q...
Old Mar 18, 2011 | 12:55 PM
mad93vr4's Avatar
Default vr4 transfer case Q...
Contact: pm
I was wondering what the difference is between the 18 spline and 25 spline vr4 transfer case. i am getting a 93 vr4 and i need to put a new tranfer case on it and need to know which one to get. thanks.
Old Mar 22, 2011 | 09:45 AM
Girly VR4's Avatar
You will most likely need a 25 spline transfer case. There is a shaft that connects from the transmission to the transfercase. This is called the output shaft. The splines on either end, and the diamater of the shaft, differ from the 18 to 25. The 25 spline transfer case, has an input spool (where the output shaft from the transmission gets inserted), with 25 splines. The splines on the shaft and spool need to correlate with each other, in order to fit together.
I hope that makes sense to you.
Also, the 6spd transmissions in the 94+ models had a 25 spline transfercase as well. HOWEVER, they will not work together. Just a note of caution.
I may have a 25 spline transfercase here in stock, if you need one. shoot me an e-mail if you are interested, and I'll check our inventory. You're also welcome to browse my site if there is anything else you are looking to get for your VR-4.
www.3swarehouse.com
-Emilie
3000GTStealthWarehouse@gmail.com
Old Mar 22, 2011 | 02:06 PM
Good to see you still around!
Old Aug 19, 2011 | 04:20 PM
Type17's Avatar
If you still care about the transfer case question, depending on your gearbox you're probably stuck with one or the other, they're not interchangeable obv.
Like GirlyVR4 said, you're probably gonna need a 25spline one since you have a 93. The good news is that the 5speed 25spline gearbox seems to be the most desired one because of the gearing and its just as strong as the legendary Getrag 6speed they put in the cars after 93.
3SX sells new transfer cases if you're still looking.
240coupe
Dec 5, 2005 09:56 PM
Andy_b_08
May 12, 2005 07:38 PM
nate5023
Nov 11, 2004 12:43 AM
Raced Guy
Aug 9, 2004 05:00 PM
magicman909
Jun 4, 2004 04:00 PM
