Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
03 diamante broke water pump and jumped teeth
Old Jun 5, 2013 | 11:05 AM
srinath's Avatar
Default 03 diamante broke water pump and jumped teeth
Hello all, My first post here.
My 03 diamante broke the water pump and the timing belt jumped 3 teeth in the front bank, and 1 in the back.
Oddly it was still running just fine as it leaked all the water.
I did not let it run and over heat etc.
Do I have to worry about piston hitting the valves with that 3 teeth jump ? or is this a valve to valve interference engine and not a valve to piston interference so I am OK.
Thanks.
Srinath.
Old Jun 5, 2013 | 12:34 PM
It is interference.
Old Jun 6, 2013 | 08:29 AM
srinath's Avatar
Yes, but valve to piston interference or valve to valve ? Cos valve to valve I dont have to worry about.
Would 3 teeth make enough of a difference to hit piston to valves ?
Thanks.
Srinath.
Old Jun 6, 2013 | 03:32 PM
You can take the valve cover off and check for bent valves. I'm willing to bet you bent some.
I believe it's piston to valve interference.
Old Jun 7, 2013 | 08:52 AM
srinath's Avatar
Default I guess a valve job
I guess I am doing valves sometime soon then.
If the valves hit the piston, would I be looking for piston damage ?
I am thinking if I dont have piston damage I'll do valves and use the car. If there is piston damage time to scrap it I think.
Cool.
Srinath.
Old Jun 7, 2013 | 12:11 PM
I wouldn't worry about any little nicks in the pistons. If you've got a crack, then you've got a problem.
Old Jun 10, 2013 | 12:17 PM
srinath's Avatar
Nothing bent, we replaced the timing belt, the tensioner, the water pump and its running fine.
The car has 161k, we replaced the water pump and timing belt @ 128k, but I dont believe we ever replaced the tensioner. I guess its an item that has to be swapped out with every belt huh.
Cool.
Srinath.
Old Jun 11, 2013 | 02:57 PM
Akzle's Avatar
Cool.
Srinath.
yes.
Lucky you though, to break a belt and not bend or drop valves.
robertjoseph
Oct 6, 2012 07:07 AM
JohnnyK
Jun 2, 2011 01:10 PM
kingarfer
Feb 19, 2008 11:05 AM
BrunoBoy650
Dec 23, 2007 10:13 PM
sturpon711
Sep 17, 2007 05:23 PM
