Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
1993 Dimante 3.0 DOHC misfire
Old Jan 2, 2010 | 12:47 AM
jawac's Avatar
Default 1993 Dimante 3.0 DOHC misfire
I have a 1993 Diamante that has a #3 & 6 cylinder misfire. I heard that these had ECM problems so I replaced the ECM with a rebuilt. It still has a misfire, so the ECM was not the problem. The tach is not reading and I can pull the coil wires off with it running and no spark. I am not sure where to go from here. I have 2 different power transistors and have tried them both. Is there something else that I am able to check?????
Old Jan 2, 2010 | 07:51 AM
dsm1990gsx's Avatar
Have you checked the coil pack?
Old Jan 9, 2010 | 02:00 PM
jawac's Avatar
Checked the coils, swapped them around to be sure, still has problem. Seems to not be getting a signal to fire the coil. STILL NO tach reading on the dash either. Does anyone know about the Power Transistor and how it functions?????
Old Aug 12, 2011 | 12:34 AM
mrmitsubishi's Avatar
Cool
i have a 93 diamante i also have no spark to coil3/6 and my tac didnt work so i replaced ignition control moduel and my car ran fine tack started to work but after a while there was no spark on coil 3/6 again so its the moduel but it is expensive its about $333 dollars but i got the moduels from junk yard so brand new will fix your car good luck if you buy it let me know if it helped
car doctor
Aug 9, 2015 04:52 PM
mitsudave
Jul 11, 2015 06:16 PM
glenner
Feb 28, 2010 08:13 PM
breezland
Dec 12, 2006 11:59 PM
BigDASH
Aug 8, 2006 09:44 PM
