2003 diamante code p0715
hey whats up guys,
im new here, but looking to fix this car i have, code p0715 came up i know its the input turbine sensor. aka the vss on the transmission, i ordered the input and and put sensor as i got a deal on both. i just need to find out where exactly these 2 sensors are located.
im pretty sure they are under the air intake. but i dont want to take this apart if i am wrong,so anyhelp would be greatly appreciated.
thanks
jeff
thanks
jeff
To Jeff and anyone else looking to solve a p0715 code. This code is primarily thrown by the computer because it has detected a problem with the automatic transmission circuitry. It will then throw the transmission in a failsafe mode where it will only go into reverse and when putting it into D drive, it will only operate in 3rd gear. That’s why the car feels like it has now power. You’re trying to take off in 3rd. You will also see the D-N indicator flashing back and forth.
The fix for this issue is to change out the A/T Transmission Relay. OEM p/n MD759545. Approx. $25.00
)) The part is located inside the car, on the passenger side of the transmission tunnel where the passengers left foot would lean against. DISCONNECT THE BATTERY NEG. FIRST, THEN: (this will also clear the p0715 code from the computer memory) ……The bottom plastic panel needs to be removed just under the glove compartment. There are 3 plastic push-pins that need to be pulled out. Afterwards, pull the carpet back on that side of the trans. just under the dash. You will then see a metal plate with 3 little screws. Remove them and the plate. You’ll see the relay bolted to a bracket just behind a big bundle of wires. Take a 10mm socket and remove the relay. Replace it and you should be back in business. Note: plug in the new relay, reconnect the battery and test it before you put everything back to be sure that’s the fix.
Hopefully you will not find the whole area full of antifreeze. That is what usually causes the problem where the heater core leaks into that area, onto the relay. There are other relay under there as well so look things over good and clean up any liquid before re-install.
BTW, there is another thread with pick of this fix on this forum. Just don’t think you have to remove the radio to do this fix as one of the pics might lead you to think.
Hope this helps. It fixed my 2003 Diamante p0715 code issue. IF it fixes your p0715 code please come back and share your experience to hopefully help out the next guys in need. I got my fix plan from that other thread, and I am sooooo grateful the guy posted it. It saved me hundreds of dollar!!!
)) The part is located inside the car, on the passenger side of the transmission tunnel where the passengers left foot would lean against. DISCONNECT THE BATTERY NEG. FIRST, THEN: (this will also clear the p0715 code from the computer memory) ……The bottom plastic panel needs to be removed just under the glove compartment. There are 3 plastic push-pins that need to be pulled out. Afterwards, pull the carpet back on that side of the trans. just under the dash. You will then see a metal plate with 3 little screws. Remove them and the plate. You’ll see the relay bolted to a bracket just behind a big bundle of wires. Take a 10mm socket and remove the relay. Replace it and you should be back in business. Note: plug in the new relay, reconnect the battery and test it before you put everything back to be sure that’s the fix.Hopefully you will not find the whole area full of antifreeze. That is what usually causes the problem where the heater core leaks into that area, onto the relay. There are other relay under there as well so look things over good and clean up any liquid before re-install.
pung06513
Feb 15, 2016 07:12 AM
pung06513
Jul 28, 2009 02:57 PM
elmiserable
Jan 20, 2009 08:13 PM
