Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
94 diamante 3.0 sohc loose wire
Old Dec 21, 2007 | 10:12 AM
Bodeen's Avatar
Default 94 diamante 3.0 sohc loose wire
I've got a loose wire, it connects on the firewall just to the right of the ID plate. It's black with a yellow stripe. I know it's a ground for 'something' but can't figure out where it was connected. It's about 6-8 inches long. I thought I'd investigate further b4 replacing alternator, HOPING it might be the problem. Thanks.
Old Dec 21, 2007 | 11:02 AM
Default RE: 94 diamante 3.0 sohc loose wire
Just bolt it down and see if that fixes it?
Old Dec 22, 2007 | 04:33 AM
Rob_D's Avatar
Without going out and looking at my 1993 TR Magna V6 I think you are referring to the base timing connection. There is a wire there on the firewall that comes to a dead end. When setting the base ignition timing it is grounded. Best to read the correct procedure before trying it though as it works on the ecu.
Rob
Old Dec 22, 2007 | 05:17 AM
Rob_D's Avatar
Here are the instructions:
[IMG]local://upfiles/15291/AFB31197092646259D8E9764D2EAA8BE.jpg[/IMG]
Old Dec 22, 2007 | 12:30 PM
Bodeen's Avatar
Bolt it down to what????? That's what I'm asking, it's connected to the firewall now, the other end of it connects somewhere, i just can't figure out where![sm=boohoo.gif]
Old Jan 12, 2008 | 12:51 PM
AFluidMan's Avatar
Stretching the wire from the point where it connects to the firewall, does it reach any part of the wiring harness, or a component? I'm thinking of the EVAPPurge Solenoid - could be attached to the intake manifold.
Old Feb 1, 2008 | 10:11 PM
jgbrules's Avatar
hello. that ground goes onto the intake. stretch the wire out as far as it goes and move it along the intake. you will see the bolt hole line up with the connector. that is a body ground and willNOT affect starting. the base time ground connector is on the passengers side of the fire wall and has a brown connector and the wire itself is about 2 inches long. usually its wraped in blue tape to the main body wiring harness. dont mess with it!! what kind of starting problem are you having?? will try to help! greg....
Shadowplane676
Jul 7, 2021 07:50 PM
Bill H
Feb 21, 2013 11:33 AM
coke6686
Dec 1, 2009 10:33 PM
coke6686
Dec 1, 2009 10:30 PM
faded2
Jan 19, 2006 08:43 AM
