Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
Alternator Replacement
Old Feb 19, 2014 | 12:43 PM
2000 Diamante's Avatar
Default Alternator Replacement
Does the alternator come out the top?looks really tight, or out the bottom. A/C compressor in the way on the bottom. Thanks
Old Feb 19, 2014 | 07:49 PM
Rame2013's Avatar
its coming out from the top. you have to remove the bracket attached to the alternator before you can pull it out. Its kinda tight but it will. It take a lot of patient take it easy don't rush. Good luck.
Old Feb 20, 2014 | 01:20 PM
California's Avatar
Default How do you know?
What makes you believe the alternator needs replacement?
Old Feb 21, 2014 | 07:53 PM
Rame2013's Avatar
OEM alternators could last 10 or more years. There's a lot of "how to" videos going on in YouTube on how to diagnose an alternator. Take note all your failing alternator symptoms and compare. In order to make sure you have a failing alternator, pull it out and go to you local auto center for a free alternator test. Good Luck!
Mazdaspeedster
Jan 14, 2013 06:57 PM
Demo86286
Jul 17, 2009 03:08 PM
opiewann
Nov 26, 2008 10:04 AM
opiewann
Oct 7, 2006 06:12 AM
bedjemp
May 19, 2005 02:02 PM
