Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
Help! '02 Diamante OBD Codes P0141, P0113, P0102, P0107
Old Feb 29, 2012 | 08:09 PM
Miles2Go's Avatar
Default Help! '02 Diamante OBD Codes P0141, P0113, P0102, P0107
My dear sweet daughter alerted me that her inspection is due on her '02 Diamante v6 and tshe wanted me to take a quick look a it for her. Low and behold she has multiple codes and her check engine light is on. Needless to say, I asked why she didn't have me or someone look at this prior to her inspection date. She said the light never bothered her (she has a picyure of my Grandkids covering it). Any help with troubleshooting these codes would be greatly appreciated.
P0141 = O2 Bank 1 Sensor 1: Is this the before or after cat. left or right? Are there any checks that I should pwerform prior to replacing the sensor?
P0113 = IAT Sensor High Input: No clue
P0102 = M.A.F Low Input: No Clue
P0107 = MAP Sensor Low Input: No Clue
Miles2Go
Old Mar 23, 2012 | 11:56 PM
mxmikie's Avatar
could it be caused by her up-bringing ????
Old Mar 26, 2012 | 04:00 PM
Miles2Go's Avatar
Why not try to help, instead of providing a useless comment. I would have thought better of a "Senior" member. I guess this forum is not for me.
Old Apr 11, 2012 | 08:40 AM
defender321's Avatar
Default Hi Miles2go
I just posted hear for the first time the other day. I'm a newbie here also, so of course I'm more willing to help, hehe. As far as the 02 sensors go, I would think the first sensor is the one before the cat. My 97 Diamante has 2 , one before and one after the catalytic converter. Under the car you can see the wire running up into the bottom of the car. I'm not exactly sure how it runs to the pcm, we started thinking it might run under the carpet.
I have had lots of codes but none you mention. There is a cleaner that they make specifically for the MAF sensor, cost me like 8 bucks for the can. If you remove the MAF and look inside all you see is a little tiny sensor that the air runs past. I would give that a good cleaning, that may remove the MAF code. Otherwise getting a new MAF can cost a lot. Hope this helps, good luck !!
swede45
Aug 5, 2015 10:31 PM
Gsteclipse22
May 6, 2008 08:05 PM
imtalkintou
Apr 27, 2008 10:30 PM
Stryker
Sep 16, 2007 08:36 PM
davesrave
Dec 21, 2004 04:27 PM
