How to adjust high end of power windows?
RE: How to adjust high end of power windows?
hello! remove the door panels and you will see the height adjusters bolted on the bottom of the glass on each side.they are round and white with a bolt going through the center. you can adjust up or down as needed, bolt is a 10mm. lossen and adjust, then tighten. if you see the hole in the glass then look in the bottom of the door, they came loose and you will have to reinstall.! good luck!! greg...
rvrexpy
01-31-2005 03:33 PM
