Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
How to adjust high end of power windows?
Old Mar 8, 2008 | 08:32 PM
dejved1's Avatar
Default How to adjust high end of power windows?
Hello,
does anybody knows how toadjust high end of power windows? I have two windows which are going to high so I cant close the door.
Thx a lot for help
Old Mar 8, 2008 | 11:53 PM
jgbrules's Avatar
Default RE: How to adjust high end of power windows?
hello! remove the door panels and you will see the height adjusters bolted on the bottom of the glass on each side.they are round and white with a bolt going through the center. you can adjust up or down as needed, bolt is a 10mm. lossen and adjust, then tighten. if you see the hole in the glass then look in the bottom of the door, they came loose and you will have to reinstall.! good luck!! greg...
Old Mar 11, 2008 | 09:16 PM
dejved1's Avatar
thx I am gonna try it!
schmez
Feb 26, 2008 08:54 AM
edaddik
Nov 13, 2005 08:49 PM
T.O.Talon
Apr 12, 2005 12:34 PM
rvrexpy
Jan 31, 2005 03:33 PM
thunderman
Nov 16, 2004 01:43 PM
