Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
lighter not working
Old Jul 31, 2006 | 04:49 PM
gdwife1836's Avatar
Default lighter not working
hi i have a 2002 mitsubishi diamante and i have a radar detector plugged into it and now it wont work on either cigg plug ins the fuse is good and the detector works in my other car. any advice? thanks
Old Jul 31, 2006 | 04:53 PM
Default RE: lighter not working
So does what you wrote mean that it doesnt work with the cigarette lighter in either. My guess would just be bad wiring. take it out and check the voltage of the connection at the lighter. See if thats fine. If you have none then its a connection at the power.
Old Jul 31, 2006 | 04:59 PM
gdwife1836's Avatar
no the lighter dosent work either. also when you first plug something into the second lighter it will come on for a second then cut off.
Old Jul 31, 2006 | 05:02 PM
The contact is pushed back a little. Get a flat head screw driver and bend them back.
Old Jul 31, 2006 | 05:12 PM
gdwife1836's Avatar
tried it still nothing everything is in place and im getting nothing.
Old Jul 31, 2006 | 11:23 PM
Check the voltage output on both terminals. Then if it shows nothing then try and get behind it to test the pos and neg wires directly... then at least if you get something out of that then you can just replace the little lighter housing thing.
Old Jul 31, 2006 | 11:47 PM
Manybrews's Avatar
if neither socket works, you DID blow a fuse.
there are far more fuses than just the ones inside the car, although those should be the ones to check.
Old Aug 1, 2006 | 11:17 AM
One box is under the hood and one is in the drivers side of the car.
mahicks3322
Nov 3, 2021 01:14 AM
jthorn75
Apr 13, 2017 11:43 PM
crashphoenix
Mar 10, 2015 12:04 PM
McNeil
Jun 22, 2009 05:01 PM
3000GTSL
Jul 27, 2004 10:42 PM
