Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
Pinion Valve Oil Seals
Old Dec 28, 2013 | 05:47 PM
tse3gbs's Avatar
Default Pinion Valve Oil Seals
I'm rebuilding a leaky pinion valve body from the rack and pinion steering on my 2002 Diamante LS, 3.5 V6.
I have the upper seal and upper bearing replaced. The valve body has been removed from the pinion housing. I have the four oil seals and lower seal to replace but don't know how to remove them from the valve body. I hear that you have to cut the four oil seals off or use a dental pick to lift them from the grooves. The issue is getting then new ones back on, as the material does not look like it stretches.
Picture of valve body attached.
Old Dec 29, 2013 | 02:30 AM
Akzle's Avatar
drill into old oil seals, screw in oversize csk screws, pull out with vice grips.
Lube new seals with clean oil or assembly grease. They dont stretch much, thats how they seal. If you have to, heat them in hot water or oil (or the oven, if wife isnt home)
Old Dec 29, 2013 | 08:43 AM
tse3gbs's Avatar
Smile
Thanks for the information, how do I address the lower oil seal near the bottom bearing, it looks like the bottom bearing needs to be removed to replace the lower seal. The lower bearing is held on by a crimped collar that can only be removed by cutting it off.
see attached picture of bottom side of pinion valve.
ricci.01montero
Mar 3, 2019 07:13 PM
ak888
May 15, 2010 10:33 AM
lillben07
1st Generation
Nov 16, 2008 03:35 PM
99clipsgst
Aug 1, 2005 08:00 PM
pinchmaster
Mar 31, 2004 02:09 PM
