Mitsubishi Diamante For the faithful Mitsubishi owner, this car offers high end luxury without high end luxury pricing.
Trying to swap ECU but can't get car to start
Old Sep 4, 2009 | 01:31 PM
voodo1's Avatar
Default Trying to swap ECU but can't get car to start
I am having problems with my transmission so I got a new transmission relay and a different ECU from a junk car.
I have tried 3 ECU units from junk cars, all with the correct part number, but none of them will even start my car.
When I am changing the units, I have the negative battery cable disconnected. When I unplug my ECU and plug the replacement unit it, I hook up the battery but none of them will do anything but crank the engine.
I then disconnect the negative cable and plug my ECU back in - fires up every time.
Do I need to "reset" something to use a replacement ECU?
Thanks.
Old Sep 9, 2009 | 10:34 PM
Manybrews's Avatar
cant just "swap" ecus. All need to have keys registered to the immobilizer ECM.
assuming you have a 2000 or newer, since you didnt say.
Old Oct 2, 2009 | 11:13 PM
jgbrules's Avatar
ditto. gonna have to tow it to the dealer
Old Apr 11, 2012 | 08:19 PM
Brucewayne23's Avatar
Default models below 2000
i replaced my ecu (explain start to finish) i checked the numbers with the old one (the one that was factory) they matched if they dont match its a no go ... disconnect old one disconnect ground (battery) or youll possibly fry your ecu plug the new one in connect ground turn ignition on (dont turn over ) turn off take key out disconnect ground then disconnect hot wait 2 min then place hott, ground in that order and start car check your dash lights after 30 sec see if any unexpected lights are on ....... thats what i did and it worked another option you can use is go to advanced or any auto parts store and grab the haynes manual for your car only 19.99 maybe a few and maybe less and that will tell you step by step from tear down to rebuild also overhaul
Sanguinius
Jan 2, 2007 09:01 PM
riphamra
Nov 16, 2006 09:38 PM
mitsubishiracer9584
Feb 16, 2006 02:23 AM
mitsu_boy
Oct 1, 2005 02:19 PM
linkin
Apr 22, 2005 02:29 PM
