Mitsubishi Eclipse & Eclipse Spyder For years, the Eclipse line has stood for cutting edge styling and performance at an affordable price.
01 elipse 2.4 p0335
Old Jul 21, 2013 | 08:56 PM
Robert Walker's Avatar
Default 01 elipse 2.4 p0335
When i was driving the car just died and would start...crank but no start... Pulled the code and it said crankshaft position sensor malfunction. When i pulled off the lower cover i found that my balance shaft belt was broke but timing belt was still intact the CPS was tore into pieces i replaced both belts and the sensor all the timing marks are aligned perfect but it still throws the same code ive erased the codes with a scan tool disconected the battery and checked the voltage going to the CPS but still no luck in clearing the code engine cranks but wont start. Please help!
Old Aug 10, 2013 | 09:07 PM
go-part's Avatar
Former Sponsor
Draco8494
Apr 17, 2010 07:58 PM
twarrior
Jun 10, 2007 01:50 PM
roseannne
May 29, 2007 01:28 PM
ERM_SPYDER2001
Jan 2, 2006 10:15 PM
magicman909
May 30, 2004 07:48 PM
