Mitsubishi Eclipse & Eclipse Spyder For years, the Eclipse line has stood for cutting edge styling and performance at an affordable price.
03 Spyder GTS 3.0 Crank no start
Old Feb 27, 2020 | 06:38 PM
03SpyderGTS3.0's Avatar
Default 03 Spyder GTS 3.0 Crank no start
03 Eclipse Spyder GTS 3.0 Will crank but not start
I have fought with this car tooth and nail for about 8 months. After purchasing the car I thought to do some general maintenance so I replaced:
Timing Belt - Crankshaft Sensor - MAF Sensor - Distributor - Plugs (3 Sets) Current set is NGK Iridium IX Part No. 6418 - Wires - Fuel Pump - Fuel Filter - Radiator (previous was cracked) - Valve cover gaskets - Oil/ Filter - Coolant
After all of this maintenance and multiple start attempts over the past 8 months it still has a hard start. Some days it will start first try but more then 80% of the time the car just will crank and not start. I noticed after having the battery charged and reinstalled the headlights flashed for a minute or so. I do not know if this is related. If anyone has any insight on this issue I would greatly appreciate the help.
thanks
Last edited by 03SpyderGTS3.0; Feb 27, 2020 at 07:36 PM. Reason: Added video of starting attempt
Old Mar 1, 2020 | 12:01 PM
Katelyn Dyson's Avatar
Definitely could be alternator. Or get a computer you plug into the dash like they have at autozone. Run it primarily to check for sensors. Sensors will screw the whole car till you replace them.
MattReed59
Oct 30, 2024 07:07 AM
Eon_eon
Feb 7, 2018 10:16 AM
dannyroblez
Mar 1, 2009 03:33 PM
dsm1990gsx
Nov 20, 2007 07:15 AM
Tom97rs
Nov 12, 2003 07:58 PM
