Mitsubishi Eclipse & Eclipse Spyder For years, the Eclipse line has stood for cutting edge styling and performance at an affordable price.
Headlights (security lights) won’t stay on when I turn ignition off
Old Nov 11, 2023 | 09:43 AM
Dhughes1432's Avatar
Default Headlights (security lights) won’t stay on when I turn ignition off
We recently purchased a 2024 Mitsubishi Eclipse Cross and for some reason the security lights won’t stay on after the ignition is turned off. Does anyone have any ideas on what the problem might be? We’ve already contacted Mitsubishi and they said they would submit a service ticket but it’s been over a week and haven’t heard anything from Mitsubishi.
Old Nov 20, 2023 | 03:45 AM
DibbyDibbyDJ's Avatar
Have you turned this on? It is adjustable through your audio unit display
Old Nov 20, 2023 | 08:06 AM
Default Solution found
Yes. We had everything on however there’s an extra step to activate the security lights. When arriving home and after turning the ignition off all we had to do is pull the high/low beam lever forward. That activates the security lights.
Old Apr 17, 2024 | 10:08 PM
Srijan's Avatar
Did you get solution.
Srijan's Avatar
did you get any solution?
Old Apr 21, 2024 | 11:56 AM
Widgmaster's Avatar
I assume the problem was solved when they did the extra step...pulled the light switch forward to activate the security lights.
PrimeTime
Jul 5, 2019 12:51 AM
txateu
Jul 23, 2013 07:43 AM
crapanotherday
Mar 7, 2012 10:42 AM
xrjay7
Nov 24, 2008 07:53 PM
iromerliciousi
Jun 15, 2007 12:36 PM
