Outlander 2010 Auto Driving Lights Problem
Old Jul 21, 2013 | 04:51 AM
txateu's Avatar
Default Outlander 2010 Auto Driving Lights Problem
Hi All
I've recently bought a 2010 Outlander (Aus model) and having a problem with the auto headlights in the car. The driving lights stay on all the time, day and night while driving the car and will only turn off when I turn the car off and open the drivers door.
The driving lights are not daytime running lights (standard on some models), as I've checked the manual, and the fuse box, and have no relays or fuses for them. One of the stalks off the steering column can be switched to manual lights but this still doesn't turn them off and I've ran out of ideas on how to turn them off.
I've taken some photo's of the stalk.
If anyone has been through this or knows how to turn them off, I'm all ears...
the parking lights symbol (green) is always on
you can see that the lights are on but its sunny outside
Thanks, Michael
Old Jul 21, 2013 | 12:29 PM
Outlaander's Avatar
Are you saying that in every possible position of the lever your headlights remain on, and that the one and only way to turn them off is to turn the ignition off?
Old Jul 21, 2013 | 09:15 PM
quadcam's Avatar
That is not an auto-headlight switch. The auto light switch has Off, Auto, Parking lights, Head lights positions. Maybe there is something wrong with the headlight switch.
Actually, was your car previously a fleet car? I have seen a mention somewhere of some fleet cars (of other brands) with the headlight switches rewired so the headlights work like yours.
Old Jul 21, 2013 | 10:04 PM
txateu's Avatar
Yes and Yes. The lights will only turn off when the ignition is turned off, and doors opened, regardless of where i adjust the light stalk to.
Also, the car was an ex gov. car, and when looking for the fuse box, I noticed that one of the wires had been spliced into.
Maybe it has been purposefully made to run with the lights on at all times? I wonder why...
Michael
Old Jul 22, 2013 | 12:50 AM
quadcam's Avatar
I would remove the spliced wire and see if that fixes it.
Old Jul 22, 2013 | 03:14 AM
txateu's Avatar
Is someone able to send me a wiring diagram? Last thing I want to do is cut a wire and then have to re-solder it, if I've cut the wrong one
Old Jul 22, 2013 | 08:54 PM
quadcam's Avatar
Can you put up a picture of the spliced wires?
Old Jul 23, 2013 | 07:43 AM
txateu's Avatar
I'll try and take one tomorrow to show you...
The wire ran along the length of the dashboard behind the glove box
marybethll
Jun 26, 2021 11:32 PM
Jenn
Sep 22, 2013 09:42 PM
lastexile
Nov 20, 2012 12:58 PM
azjake
Nov 29, 2009 12:07 PM
buck6680
Apr 1, 2009 09:01 AM
