04 endeavor low idle
Old Jul 11, 2011 | 09:35 PM
Bardcastle's Avatar
Default 04 endeavor low idle
After replacing the battery on my wife's 04 Endeavor, it started idling very low (200-500 rpm). my mechanic told me the regulator was bad. I replaced the alternator, but it still happens. It idles very low, sometimes causing a stall. when idling so low, battery is reading 12.7 volts (more or less), but if someone keeps rpms at 1000+, it shows 14.3 (more or less). What is causing this idle drop? Check engine light is not on.
Old Sep 15, 2013 | 12:53 PM
david.k1200's Avatar
I had almost the same situation, after replacing the battery the Endeavor would not remain at idle the engine would shutoff. I found out the idle had to reset itself, so by driving and using the gas pedal the idle did not reset itself. I had to disconnect the battery (change the oil while disconnected) then I reconnected the battery and let the Endeavor idle for 10 minutes to relearn the idle speed. Now the Endeavor runs fine and does not shutoff.
Old Sep 21, 2018 | 11:42 AM
Shanen Rose's Avatar
Default Low idle/stalling
Thank you for sharing ... I'm having the exact same issue. I was told just to drive it and it would reset itself. It's been several days now and no change. I'll try out the method that resolved your issue. Thanks again!
Old Oct 7, 2018 | 07:00 PM
yarchlrl13's Avatar
disconnect both terminals and zip tie them together. wash the suv, vacuum it, armor-all the tires(in other words, let it sit 15 mins, lol) then reconnect the terminals, start the car and let it sit and idle for 10-15 mins, then drive it for 5.
Old Jun 18, 2019 | 10:37 AM
Panama Jack's Avatar
Default Clean the Throttle Body
Sometimes by cleaning the Throttle Body, fixes the problem. You should be at around 8,000rpms-1,000rpms after cleaning it.
I hope it helps!
Regards,
PJ
agallardo
Apr 21, 2006 12:23 AM
nightseer
Jan 25, 2006 01:14 AM
drith
Jan 3, 2006 12:48 AM
cocosun
Aug 9, 2005 01:52 AM
autorok
Jul 1, 2005 02:33 PM
