'04 Endeavor LS AWD Tailgate Problem
2004 Mitsubishi Endeavor LS AWD
So here is my new problem. My tailgate wont open. This happened about 2 years ago and the mechanic narrowed it down to the tailgate release handle. I think he said there are two contacts in there and they weren’t working so the actuator wouldn’t engage and open the tailgate.
So now I have the same problem. I bought a new tailgate release handle and it still doesn’t work. My mechanic took everything apart and learned that there is no current going to the tailgate release until the handle is pressed and then the actuator will pop the tailgate. We have done everything, fuses are okay, wires are okay, I think I once saw this is a known problem with the Endeavor.
So you have any suggestions?
Thanks,
Howard Douglas
Looks like I have the same problem. It happened earlier this evening. When your mechanic looked at it 2 years ago, did he find a solution? Did you buy a new release handle from a dealership? Did the dealership install it or was it your mechanic? When you find an answer or some clues, please post.
GTS 2.4
09-09-2011 01:48 PM
chili_g
04-27-2008 08:48 PM
