06 mitsubishi endeavor window problem
Old Apr 22, 2022 | 03:38 PM
Heather.Anhorn's Avatar
Unhappy 06 mitsubishi endeavor window problem
2006 mitsubishi endeavor my passenger side window will go down but to go back up I have to ground the motor at same time I roll it up
Old Apr 22, 2022 | 03:42 PM
I've replaced the whole wiring harness in my door then the window worked for a day and then right back to where I started where it goes down as normal but have to ground the motor for it to go back up
Old Apr 23, 2022 | 11:25 AM
whilst01's Avatar
Check the switch.
Old Apr 24, 2022 | 08:28 AM
I have replaced both switches and didn't do anything I'm thinking it has to be the wiring harness behind the stereo
Old Apr 24, 2022 | 11:24 AM
whilst01's Avatar
Find out where it receives ground...
Old Apr 25, 2022 | 09:04 AM
whilst01's Avatar
Check wiring where it passes from door to body of car.
The accordion like rubber grommet that hides/protects wires.
Opening/closing door can sometimes fracture - pinch wires.
My van had that problem. Broken ground wire..You can check by gebtly peeling back from each end .
I had to cut mine ,carefully, to reveal and repair wiring.
I then used RTV to seal.
Good Luck.
Old Apr 26, 2022 | 01:33 AM
Default My window problem
Good Luck.
I've replaced that whole wiring Harness from the inside the door to just past the accordion thing and it worked for the day then I'm back to where I started cause it does the exact same thing now again
Old Apr 26, 2022 | 06:18 AM
whilst01's Avatar
Default window problem
I would trace / check ground from Master Switch onward.
Most vehicles get their connections from that switch.
Q: The rear windows work properly? At 'master' as well?
Also, are the switches 'aftermarket'?
I've purchased those cheap ones before and some have been faulty from the getgo.
Old Apr 27, 2022 | 02:58 AM
Whats the master switch the one on the driver side ? And the back widows did both work but recently one of them stop working to
Old Apr 27, 2022 | 12:30 PM
whilst01's Avatar
Yes. The 'Master' switch is the one in driver's door that has all the switches.: all windows,locks,etc.
