07 Endeavor SE electrical ?
Old Mar 10, 2014 | 08:43 PM
brennan.wallace's Avatar
Default 07 Endeavor SE electrical ?
I have an 07 endeavor SE with 90k miles. Recently my tire air pressure light starting flashing indicating one of my valve stems pressure sensors is bad so I thought. But it comes on sometimes but not always. Then 2 days later now my radio makes a humming noise when on (whether in cd or radio). Then today my tcl light came on even though I didn't hit the tcl button. When I turned off the car and turned it back on it did not come back on again.
Anyone else had any of these issues? I starting to think that maybe there's an electrical problem or something?
Old Mar 14, 2014 | 07:30 PM
Well it doesn't appear to be an electrical issue causing these issues. I hooked up a Snap On computer and the TPMS light was on due to wheels 1 and 4 having low voltage from the sensors batteries dying. The traction control light wasn't throwing a code so haven't figured that out yet but I'm being told it's probably a bad sensor causin it. Haven't figure out the humming noise yet but I suspect it may either be a bad ground wire somewhere or the factory installed amp is going bad.
$130 and both sensors were replaced today.
Old Mar 14, 2014 | 09:49 PM
Akzle's Avatar
totally worth it.
Old Mar 15, 2014 | 08:51 AM
Called around to several different tire shop, they all wanted between $85-$95 per sensor plus $20-$30 to install each sensor. Shopped around and found the sensors for $39 each at NAPA and PepBoys installed them both for $49 !
Now to figure out the traction control sensor ....
stolidmind
Nov 9, 2022 07:53 PM
FAUEE
Mar 2, 2011 12:18 PM
m3kgt_99
Sep 28, 2004 12:38 PM
HoloSkull
Sep 13, 2004 12:17 PM
